My lightbox has stopped working. I use Featherlight (Featherlight Disabled fork). Uninstalling all plugins except GP Pro doesn’t fix it, but uninstalling GP Pro does. I’ve tried with native WordPress lightbox and it has the same problem, just click and nothing happens. I think it stopped working after 6.5.3
Do you mean GP Premium or GB PRO?
Sorry, GP Premium
Just confirm, if you keep GP Premium activated and deactivate all modules:
https://docs.generatepress.com/article/installing-gp-premium/#activate-your-modulesDoes that solve the issue?
If so can you activate the module one by one and try to identify which module is causing the issue?
Let us know 🙂
No, that doesn’t solve the issue, only deactivating the whole plugin.
I just tested in the same environment, but the lightbox works well. I don’t think GP Premium’s causing this issue.
Do you have a child theme? If so, can you disable it to test?
And can you provide an admin login for us to check the backend while keeping all plugins deactivated?
