Hi, I’m trying to optimise my website for mobile use and checking this page https://www.batterydesign.net/hina-nacr32140-mp10/ on Lighthouse I get a warning:
Specifying
overflow: visible
on img, video and canvas tags may cause them to produce visual content outside of the element bounds.This warning appears on all pages as far as I can see, just not sure how to fix the ‘overflow: visible’ issue.
Best regards, Nigel
Hi Nigel,
I didn’t see this specific issue when I do the lighthouse test for your site.
Can you take a screenshot of the issue in the lighthouse test result? It would be helpful if I could see which images are flagged.
hope this helps
It doesn’t seem to have this issue when I do the lighthouse test, the best practice section scores 100.
https://app.screencast.com/LxyzlBXjnbgfrThe issue seems related to https://github.com/WICG using deprecated APIs.
I would recommend reaching out to the WICG’s support for this if the issue persists.
thank you, I will take a look.
interesting that the scores were different – thanks for checking
