aaronmckeon
I’m creating a block content template that shows a staff member’s biography. The biography is setup as a custom WYSIWYG field using ACF called
biography
. In the editor, paragraphs display properly separated by line breaks. However, the content that is displayed on the screen strings all the text together in one paragraph. I’ve tried using a heading block formatted as both P as well as DIV, but neither works. What is the correct way to display this content?Screenshots: https://postimg.cc/gallery/SSPXsJK
Is the GB Pro plugin enabled?
aaronmckeon
That fixed it, thanks. It’s not clear which features require the pro plugin be enabled, and I did not know that was one of them.
To keep the format (including WYSIWYG, date, time, etc) from the ACF fields requires GB Pro 🙂
