garrigui
Hi, I use the following CSS to style the
<li>
of my content:.entry-content>ul { list-style: none; margin-left: 0;} .entry-content>ul>li { position: relative; padding-left: 20px;} .entry-content>ul>li:before { content: ''; display: block; width: 9px; height: 9px; border-radius: 2px; background-color: #39ba32; position: absolute; left: 0;
I would like to know how I can apply this style in the
<li>
that I apply inside the new GenerateBlocks accordions. Thank you so much, -
Hi Garrigui,
For clarity, can you edit your topic and place all code in code tags? See: https://share.getcloudapp.com/L1uDZN41
Some of the text of your message seems to be missing.
Also, for support, can you add your support key for GenerateBlocks Pro to your account here?
garrigui
.entry-content>ul { list-style: none; margin-left: 0;} .entry-content>ul>li { position: relative; padding-left: 20px;} .entry-content>ul>li:before { content: ''; display: block; width: 9px; height: 9px; border-radius: 2px; background-color: #39ba32; position: absolute; left: 0; top: 7px;}
can you share a link to your site where we cans see the issue ?
garrigui
Until now I used the plugin Lightweight Accordion, but with the incorporation of the accordions in GenerateBlocks I would like to know to which class I should apply the style that I have shown you.
An example of styling lists with the Lightweight Accordion plugin is this:
https://www.banyeresdelpenedes.cat/ajuntament/horaris/And I’d like to apply it to a page like this that uses the new GenerateBlocks accordions:
https://www.banyeresdelpenedes.cat/temes/medi-ambient/analitiques-aigua/The style I use for the lists (<li) is this:
Thanks!!
Ok, this:
.entry-content ul { list-style: none; margin-left: 0;} .entry-content ul>li { position: relative; padding-left: 20px;} .entry-content ul>li:before { content: ''; display: block; width: 9px; height: 9px; border-radius: 2px; background-color: #39ba32; position: absolute; left: 0; top: 7px; }
garrigui
Thank you very much David, it works perfectly.
Finally, I would like to know how I can remove the bottom margin that exists within the content of the accordions, so that it is at the same distance as the top margin.
Example: https://www.banyeresdelpenedes.cat/municipi/entitats/
Thank you so much,
You can remove the bottom margin from the last list inside accordion content with this CSS:
.entry-content .gb-accordion__content ul:last-child { margin-bottom: 0; }
