girlfriday
I am using the Top Bar widget space to put some content above my logo/nav. I have it set in a double container / 2 column grid so that text will be on the left and buttons will be on the right.
However, I can’t seem to set it to fill the space, the block is always set to be right aligned with an auto margin on the left. I have the sizing of the parent container set to max width and 100%.
Is there a setting I’m missing to make this fill the full width of the widget space? I suspect I can do it with CSS but I’m still getting used to 3.0 and I’m not sure if I’m missing something
Just to confirm that the topic is resolved as it’s marked as resolved.
girlfriday
Oh no, not resolved — odd, must have been a mis-click! I still have this question. Thanks!
Hello there,
For reference, can you share the link to the site in question? We’ll check your setup.
girlfriday
Sure — it’s in the private information (it is a staging site currently)
I see. The Top bar widget has custom CSS forcing content to the right.
An alternative is to use a Block Element – Hook hooked to
before_header
to add those Blocks. -
girlfriday
Gotcha — okay! I thought I was maybe missing something with the new 3.0 layouts, but this makes sense. Thanks!
You’re welcome!
