Tomek
I need to map the layout of the blog like on the page: https://theadminbar.com/blog/ . I have a small problem because the vertical and horizontal spacing is not equal and I can’t change it. It’s about equal spacing as on the example page above. Data for my page in a private message.
This doc should help:
https://docs.generateblocks.com/article/vertical-alignment-of-content-in-grid-container/Let me know if you need further assistance on this π
Tomek
I learned something new. The problem I have is that when I set the margin of 20 px on the right and on the left, the spacing between my posts (top and bottom) becomes different (larger). How to keep the current layout and add 20px margins to the right and left (from the edge of the screen) and keep all the current layout?
Not sure this is the case, I tried removing the left/right margin on your posts, the top/bottom spacing doesn’t change.
Here’s what I see:https://app.screencast.com/5Wf3a371EcWuM -
Tomek
Hi Tomek,
I’m not seeing the Grid of posts on the link you shared right now. Did you remove it?
Tomek
I didn’t delete anything. Everything is the same, I updated the link in a private message, it directs directly to the blog
try adding this CSS:
.generate-columns-activated .site-content { padding-inline: 20px; }
You may need to refresh the browser to ensure the masonry calcs update to compensate for that.
Tomek
Thanks David. I’ll have to apply to Tom Usborne for a raise for you π
π Glad to be of help
