websquared
Hello
Is there a limit on the number of elements? I have a site that I need to create 3 elements per section and there are 50 sections… so 150 ish – just to start with
I don’t believe I can automate this (as 1 is a layout config, 2 are blocks – with images that change depending on which section we are in..)
So would 150 elements cause issues? obviously I am hoping that as only 3 are called per page – that the
LOCATIONS
andEXCLUSIONS
minimise things?Before I get too far down this route I thought that I would ask first
Thank you
Sarah -
Yes, it will slow down your site likely.
You will have to find a way to automate it, 150 elements just don’t sound right. And it will be a lot of manual work.
Can you explain what will the content be for the 3 elements so I can see the possibilities of automate them?
websquared
Hi Ying
Hmm that was my worry – is the
location
not the same aswidget options
ie show and hide things in certain pages?anyway this is a school site and so each school is a category in woo and each school has own name, banner, colour and sidebar, then each school has own products and sub-cats
I was using elements to set
1 a sidebar as a layout (for each school but maybe I can do that for all schools actually…)
2 the content for that sidebar (I could use widgets andwidget options
plugin but was hoping to reduce plugins) as that is different for each school
3 the header has a image, logo and name (name is actually the school category name but I was not able to use the dynamic data to display that – if I could then I could reduce a few more as there are a handful of schools the same sidebar details but that only saves me a handful..)when I have 50 schools (& rising) 3 elements per school – that is how I get that number
even if I created a template for each school that would still be 50 templates..
very open to thoughts on what else I can do though – but this was in magento and I had to create blocks and widgets for each school using that as well ..
any other ideas very welcome
thank you
Sarah -
1. if all schools have a sidebar, you can enable the sidebar layout at customizer > layout > woocommerce.
2. you can use block element – sidebar: https://docs.generatepress.com/article/block-element-sidebar/
3. Set the dynamic content to
title
via GP’s dynamic option in the floating toolbar.when I have 50 schools (& rising) 3 elements per school – that is how I get that number
You need to create custom fields for the product categories, then you can dynamically pull the data via elements, so 3 elements at most is what you need.
websquared
2. I did not know of this option – thank you – however each school has different sidebar content, so I don’t think I can do that with 1 element
custom fields for product categories – I will look into what you mean by that! (Is that ACF custom fields?)
Thank you def food for thought here!!
Sarah
What kind of content? I really think you should look into custom fields, a plugin like ACF can be very helpful. It can help you reduce so much manual work 🙂
websquared
yes I will go do that – the content is usual content, PDF’s links, text, imagery etc nothing too taxing – I gues I was in the mindset of only using GP etc – but I can add ACF and use that also – thank you appreciate the advise
Hope everything goes smoothly! -
websquared
Hi Ying – is there any docs about what GP/GB block, hook, template etc and what they all do – so that I can work the way through pulling in ACF data? I am getting a little bogged down in hook/block/content template and the variety of dynamic data AND then the Display options appears or not – and again not sure which I should be using – I don’t want to take up your guys time on this, but looking through all the forums etc I am not finding anything I can check out ?
Here are all the doc for GP’s block elements:
https://docs.generatepress.com/?s=block+elementGB’s doc:https://docs.generateblocks.com/
GP’s doc:https://docs.generatepress.com/And here’s GP’s and GB’s YouTube video channel:
https://www.youtube.com/generateblocks
https://www.youtube.com/generatepressHope that’s helpful 🙂
