fcacic
Hello there! I have a small issue with the GeneratePress simple megamenu.
As stated in the title, mega menu is 100% width of the sticky header, and I want it to be exactly like on the regular header.
I’ve tried some css solutions from the other threads, with no luck so far.
Site is maintenance mode so I will leave all the login data in the private info π
Try this css:
.is_stuck .main-nav#primary-menu { position: relative; } @media(min-width:769px) { nav.is_stuck .main-nav#primary-menu .mega-menu>ul { width: calc(100% + 81px); } nav:not(.is_stuck) .main-nav#primary-menu .mega-menu>ul { width: 100%; transition: none; } }
fcacic
Thank you so much Ying, works amazing! π
I will close the thread now, thank you very much.
No Problem π
