purevelvetdesign
Is it possible to use the mega-menu without the sub-headlines?
https://docs.generatepress.com/article/building-simple-mega-menu/ -
You should be able to hide them using CSS.
can you link me to your site?
purevelvetdesign
I think I could solve this by CSS 🙂
Do you know how the reduce the container so that’s similiar?
I also set not Shop Page in WooCommerce > Products > Shop Page > [empty] but it still shows the Shop Page there?Best regards
André -
purevelvetdesign
Ah and how to hide these entries in Canvas menu on mobile?
Is there a solution?Best regards
Looks like you’ve reduced the height already, have you figured it out?
Which entries? And I didn’t see mega menu on the desktop, did you disable it or it’s still cached?
https://app.screencast.com/WHsSCLUKhRDnN -
purevelvetdesign
Hi Ying,
it’s the width or padding not the height. Do have an idea that it is consisent to the other containers?
Actually I remove the MegaMenu because you have these titles then also in the Canvas Menu and can’t hide them.Best regards
André -
I can no longer see your site, it times out during loading.
Can you check?
And please enable the mega menu so I can work on it.
purevelvetdesign
should be online. It is on my end.
Best regards
André -
I’m still not seeing the mega menu:
https://app.screencast.com/DOB50XQEXfBv3 -
purevelvetdesign
I removed the MegaMenu because in the OffCanvar Menu it’ is not possible to not have the Sub Headlines. Or is there a way?
Can you please have a look regarding the consistend container width I don’t get it.Best regards
André -
in addition to the Mega Menu CSS, you would add:
.main-navigation:not(.is_stuck) .inside-navigation { position: static; } .inside-header { position: relative; }
purevelvetdesign
Hi David,
Thank you very much. I will try out.
Could you also have a look to consistent container width I mentioned here or should I start a new ticket?
Screenshot is in “private info”.Thanks.
Best regards
André -
Sorry i may have completely mis read the issue.
The CSS i provided above would make it so the Mega Menu spans the width of the site header when its static or sticky.Was that an issue ?
purevelvetdesign
Hi David,
no problem, I maybe mixed up here two topics 🙂
1.My origin question regarding MegaMenu was if it possible to hide the Sub-Headline and to only have to menu entries maybe 4-5 in a Column withouh Sub-Menu Headline.
2.My second request was regarding the different container width issue I have regarding WordPress and WooCommerce container as you can see in the screenshot in the “private” area.
Ah ok, so to save me from getting confused ( its easily done lol ). Could you raise a separate topic for the container widths question.
And if i understand correctly, on the menus if you just want the sub menu in say 4 columns without adding more parent / chid items then try this CSS:
.main-navigation .mega-menu { position: static; } .main-navigation .mega-menu .sub-menu { column-count: 4; width: unset; padding-block: 20px; } .mega-menu .sub-menu li { display: inline-block; }
And just add the
mega-menu
class to the parent menu item -
purevelvetdesign
Hi David,
Thanks, this works well.
Best regards
André
