Gareth711
I noticed that my site laseruser.com had a problem with the menus not working as well as clickable links.
Reading through some forums it seemed that menus are controlled by the theme, hence this message.
I’ve determined that the issue seems to be related to the WooCommerce plugin. If I disable WooCommerce, the menu functions work.
I have a staging site that works fine (WooCommerce is in safe mode for a staging site) and if I am logged into wordpress for my main site, I have no problems with the menu.
I rolled back a wordpress update and numerous plugin updates to a known good point, but still the same issue with the menu.
Any suggestions on what I can do next as I chose GeneratePress for it’s WooCommerce compatibility?
can you disable the Ezoic caches and optimizations ?
Gareth711
yes, but the site has been working with ezoic for
2 years. -
Gareth711
deactivated
Gareth711
My apologies, that seems to have fixed the issue
I’ll now check the ezoic settings -
Gareth711
Looks like the conflict relates to Ezoic optimisation for Critical CSS
You may just need to regenerate that used CSS.
Glad to hear you found the issue!
