Treasureweb
I have the menu in the left sidebar, but it is not showing up. What am I doing wrong?
Thank you
Treasureweb
I was able to get the menu in the left sidebar, but I want it to look like this: https://nerdhaven.games/
How can I dublicate this?
Thank you
the easiest method to do that would be to use the Sider site from the Site Library as it has that same navigation layout.
See here:
Treasureweb
That worked, but how do I make the page full width. I do not want any space around the main content.
Thank you,
Treasureweb
That worked, but I would like the top image to take up the entire width and height from side to side and right to the top.
Thank you
Treasureweb
I just want to be clear…. I would like the image at the top of the content to take up the entire width and height from left menu to the far right all the way to the top.
I still want the menu on the left, like this https://nerdhaven.games/
Ok, the site uses some CSS for its layout.
In Customizer > Additional CSS look for:body { padding: 0 50px 50px; margin-left: 300px; }
remove the
property.Also there is this CSS in the customizer, maybe from a different site (?)
.no-sidebar:not(.archive):not(.blog) .inside-article > *, .no-sidebar:not(.archive):not(.blog) #comments, .no-sidebar:not(.archive):not(.blog) .paging-navigation { max-width: 700px; margin-left: auto; margin-right: auto; }
Can you also remove that.
That should provide the full width container area you need.
Let me know. -
Treasureweb
Thank you very much. That worked great!
Glad to hear that!
