I’ve got a site running GP Premium and Generate Blocks Pro. Trying to add a hook for menu_bar_items, but it straight up does not exist in my list of available hooks. I’ve checked the versions and am running all the latest. Only thing I can think is it doesn’t like something about running a child theme, but that doesn’t seem it, either.
What am I missing?
If I type it in, it’s just not in the available options: https://imgur.com/a/cQkvgP5
Could you check in the Customizer > General settings if there is a Structure option that is set to Floats? If it is, then change it to Flex Box. After that, you can retry adding the hook.
Let’s see how it goes.
That’s wisdom and experience at work, my friend! Yes, that did it.
I would not have thought to look there in a million years. This is an older site that’s been running GP for probably 5+ years now and some of those features that weren’t auto-updated to some other format just never get or got changed.
Yeah that explains it. This was due to the GP 3.0 update, and the
menu_bar_items
hook exists in the Flex Box structure. Thus, legacy sites would need to change the structure to use it.Glad it helps!
