Missing image title attribute
  • Hello
    I’m trying to add alt and title tags to images. I can see the alt tags in the source code, however, I can’t see the image title tag in my source code. I have added both the alt and title tags in my media library.
    Hopefully this makes sense.
    Thanks in advance.
  • Hi Henke,
    Are you using the GB Image Block? If not, can you try using that instead? The GB Image Block loads the Media Library title of the image by default, and you can also replace it through the settings. Reference: https://docs.generateblocks.com/article/image-overview/#title-attribute
