vinnymo
The mobile menu on my website (https://soccer-formation.com/) isn’t working.
The plugins StackCache and perfmatters were installed. I’ve disabled StackCache and have removed the Javascript Delay & Defer options from perfmatters and cleared the cache. The mobile menu still isn’t working.
Please can you provide some guidance as to what to do next?
Regards
Hi Vinnymo,
To be sure, can you try #1 here to debug: https://docs.generatepress.com/article/debugging-tips/
It’s recommended to backup your site before proceeding with this.
vinnymo
Hey,
Thanks for the quick reply. I deactivated the plugins one by one and as soon as I deactivated the perfmatters one, the menu appeared. What is it that I need to look out for? Should there be some javascript files I need to defer or be exempt from their plugin?
Regards
Try excluding
mobile.min.js
vinnymo
Hey Fernando,
I just did the following…once I knew the issue was isolated to the perfmatters plugin, I reactivated it and clicked the ‘Clear Used CSS’ button (the Defer & Delay Javascript options are activated). I checked the website again (with the plugin activated) and the menu is working.
Regards, Vince
I see. Glad you got it working now!
