usethebitcoin
Hi
I have a problem, inside single post mobile view, when you scroll down until footer, something is showing after footer, it’s a navigation if I’m going to set the css class into display: none, the 404 element is showing too. I have checked the elements but I can’t find the culprit.
Could you pinpoint exactly which part? I’m viewing on mobile but can’t seem to find it. If you’ve hidden it, please revert it so we can identify the issue.
usethebitcoin
Hi Alvind,
It’s weird, I removed all the classes that I set to display none and it didn’t show up. I’ll inform you once I encounter it again.
Sure, just ping here!
usethebitcoin
Hi Alvind,
I changed our ticker and now it is showing below the footer. I created a hook and choose before_header for the ticker.
I don’t see your site link, can you provide that?
Let me know π
usethebitcoin
Hi Ying,
Pls check π sorry about that
No problem π
I see you’ve opened several topics for this same issue, it’s going to create some chaos.
I would recommend sticking with one topic.
I’ve asked you to provide the HTML code you added to the hook element, let’s stick with that topic.
