marclevesque
How can I move the right sidebar menu below the right sidebar header widget?
In effect, I want my site title to end up in the right sidebar above the menu (and then I’d like to remove the current site title that’s at the top of the page).
You should be able to adjust the sidebar widget under Appearance > Widgets.
marclevesque
Hi Alvind,
My menu doesn’t show up there. After I moved the menu to the right side bar I can’t see it under Widgets > Right sidebar, and all widgets I add to the sidebar are added below it.
That is correct – setting the Navigation Location to Right sidebar does not make it a widget.
Try this CSS to change the order:
.sidebar .inside-right-sidebar { display: flex; flex-direction: column-reverse; }
Learn how to add CSS: https://docs.generatepress.com/article/adding-css/
Let me know if this helps 🙂
marclevesque
This works but I’d like to have the possibility of adding other widgets like a search box after the navigation menu.
I there another way to get some text above the navigation menu?
You can give this CSS a shot:
.gen-sidebar-nav:before { content: "Notice 52"; font-size: 35px; }
marclevesque
Hi Alvind,
That’s good too.
When I add padding, top and bottom work but they don’t have an effect on spacing. Is there another way to affect spacing?
Also, when I add background color, left padding works and affects spacing from the sidebar edge, and right padding works too but the padding’s right edge doesn’t follow the dynamic sidebar width, is it possible to have it follow?
Sorry I’m new to this, thanks for your help.
Marc
Sorry, what do you mean by spacing? Do you mean the left/right padding?
If so, it should work for the
:before
pseudo-element as well. I took a screenshot, as you can see the left/right paddings are applied.
https://app.screencast.com/7L5W9SAH6lb1dis it possible to have it follow?
Yes, you need to make it
display:block
.So change your CSS to this:
.gen-sidebar-nav:before { content: "Notice 52"; font-size: 35px; padding-top: 0px; padding-right: 25px; padding-bottom: 25px; padding-left: 18px; background-color: lightgray; display: block; }
marclevesque
Adding display:block fixed both issues: 1) the background color filled the sidebar width and 2) the top and bottom paddings started to affect top and bottom spacing (before the padding was just “bleeding” on top above the sidebar and below onto the nav menu).
