Humanovation
This is an odd one that I just can’t figure out …
I moved my posted and updated dates to the bottom of the post using:
add_filter( ‘generate_header_entry_meta_items’, ‘__return_empty_array’ );
add_filter( ‘generate_footer_entry_meta_items’, function( $items ) {
return array(
‘date’,
‘author’,
‘categories’,
‘tags’,
‘comments-link’,
‘post-navigation’,
} );… in the functions.php.
When I had them above the post, they displayed in the order posted date then updated date. Oddly, now that they are below the post, they display updated then posted. I want posted date to be first on the line like it was at the top but I just can’t get it there π
try replacing this CSS:
.posted-on .published::before { content: " | Posted: "; }
for this:
.posted-on .updated::before { content: " | Posted: "; } footer.entry-meta .posted-on { display: flex !important; flex-direction: row-reverse; justify-content: flex-end; }
Humanovation
Such an odd one … that switched them into the correct order, but now they are centered instead of left justified with the rest of the meta and I can’t seem to create a “space | space” between the the 2 … π
Humanovation
Ahh, they are right justified for somoe reason, not centered. Maybe because of the row-reverse command?
I edited the CSS above – should fix that
Humanovation
That did it … thanks David π
Glad to hear that!
