stranflow
Hi-
Playing around in the global styled editor and don’t see changes in the page editor unless I refresh the browser.
My dev is able to see the real-time changes to the style. I cannot.
Video example in the private info.
Thanks for the testing and feedback. couple of questions:
1. is it any style that you change or is it just the Margin ?
2. is it only happening in the Brave browser ? -
stranflow
Hi David-
It was any style.
But I switched over to Chrome and it’s working.
All set!
Ok, glad to hear that.
I’ll check with the team, i believe one Dev uses Brave to see if he has experienced anything similar. Might be worth testing with Brave without any exetensions installed in case one of those is conflicting. -
stranflow
Actually, I am in Chrome now and I don’t see locally loaded fonts in the editor. Have to go into preview mode.
What can I share with you to check?
Yes, I went into incognito with Brave and it didn’t work.
Can you provide an admin login and share the page in question where the global style and local fonts being set?
stranflow
Updated with info below.
Thanks Yin.
The
font-family
of the paragraphs is set toFFDIN
.Local fonts do not show in the editor, because the editor does not load
@font-face
CSS by default, so this is expected behaviour, you can check the regular pages to confirm this.
https://app.screencast.com/gmlQCABrl72WsAre there any other styles I should be checking?
stranflow
Is there a work around to have custom fonts appear?
Posted a new link where it appears another custom font is showing in the preview.
I don’t think the global style is showing the correct font, compared to the front end of the homepage, you can see both are set to font
Cotford Display
, but the backend and front end are showing different fonts:
https://app.screencast.com/HcByiroDlHrDVTo show local fonts in editor, we provided a snippet in the local fonts doc:
https://docs.generatepress.com/article/adding-local-fonts/#show-local-fonts-in-wp-block-editor -
stranflow
Hi-
Put the code snippet in.
new loom showing what’s happening.
The code is PHP, it’s not CSS.
Learn how to add PHP code: https://docs.generatepress.com/article/adding-php/
stranflow
I only got an hour of sleep last night!
Get some more sleep 😛
