Anders
How do I make a mobile menu like this site?
the 3 element can be “hard coded” but the last “Menu” item needs to be the menu.
Is this possible in generatepress?
For the ‘Menu’ part, you can use a button block to trigger the menu to open when clicked. Here’s a topic that has a similar use case to yours.
https://generatepress.com/forums/topic/open-off-canvas-panel-using-icon-or-button-link/ -
Anders
Hi Alvind
Ok, thanks – but then how do I get the open/close animation effect – on the button – that the current menu items has in generatepress?
the Buttons icon field would need to include 2 x SVGs for the icon.
One for the Open state and one for the close state eg,<svg viewBox="0 0 512 512" aria-hidden="true" xmlns="http://www.w3.org/2000/svg" width="1em" height="1em"><path d="M0 96c0-13.255 10.745-24 24-24h464c13.255 0 24 10.745 24 24s-10.745 24-24 24H24c-13.255 0-24-10.745-24-24zm0 160c0-13.255 10.745-24 24-24h464c13.255 0 24 10.745 24 24s-10.745 24-24 24H24c-13.255 0-24-10.745-24-24zm0 160c0-13.255 10.745-24 24-24h464c13.255 0 24 10.745 24 24s-10.745 24-24 24H24c-13.255 0-24-10.745-24-24z"></path></svg> <svg height="1em" width="1em" xmlns="http://www.w3.org/2000/svg" aria-hidden="true" viewBox="0 0 512 512"><path d="M71.029 71.029c9.373-9.372 24.569-9.372 33.942 0L256 222.059l151.029-151.03c9.373-9.372 24.569-9.372 33.942 0 9.372 9.373 9.372 24.569 0 33.942L289.941 256l151.03 151.029c9.372 9.373 9.372 24.569 0 33.942-9.373 9.372-24.569 9.372-33.942 0L256 289.941l-151.029 151.03c-9.373 9.372-24.569 9.372-33.942 0-9.372-9.373-9.372-24.569 0-33.942L222.059 256 71.029 104.971c-9.372-9.373-9.372-24.569 0-33.942z"></path></svg>
We can then use some CSS to show hide the relevant icon based on the off canvas menu state.
body.slide-opened .gb-button.menu-toggle svg:first-of-type, body:not(.slide-opened) .gb-button.menu-toggle svg:last-of-type { display: none; }
The
slide-opened
class gets toggled on the root HTML element,
So the class is present when the off canvas is open, and we hide the relevant SVG based on that class state -
Anders
Managed to get this far.
The menu item is not visible for some reason, and does not trigger the menu.
Can you help?
1. go to customizer > layout > off canvas panel, and set it to
on
, instead ofmobile only
.2. add
slideout-toggle
andhas-svg-icon
class to the container, remove themenu-toggle
class.3. add this CSS to hide the slide out button on desktop:
span.menu-bar-item.slideout-toggle { display:none; }
Let me know how it goes 🙂
Anders
Works perfect… thx
No Problem 🙂
