thomaspaylor
Hello
I’ve just jumped over to the Generateblocks website to use the pattern library. I can see this has now changed and that I need to load the pattern library directly from my WordPress editor. When I click on the Generateblocks pattern library button, it starts to load, and then crashes. I then get the following error…
The editor has encountered an unexpected error. (I have replaced my actual domain name with http://www.mydomain.co.uk)
Copied error test as follows: Failed to read a named property ‘document’ from ‘Window’: Blocked a frame with origin “https://www.mydomain.co.uk” from accessing a cross-origin frame.
at https://www.mydomain.co.uk/wp-content/plugins/generateblocks/dist/pattern-library.js?ver=714757ab18b461bf9f2b:2:3149
at Ur (https://www.mydomain.co.uk/wp-includes/js/dist/vendor/react-dom.min.js?ver=18.2.0:10:73411)
at El (https://www.mydomain.co.uk/wp-includes/js/dist/vendor/react-dom.min.js?ver=18.2.0:10:93232)
at https://www.mydomain.co.uk/wp-includes/js/dist/vendor/react-dom.min.js?ver=18.2.0:10:89834
at v (https://www.mydomain.co.uk/wp-includes/js/dist/vendor/react.min.js?ver=18.2.0:10:3385)
at MessagePort.ce (https://www.mydomain.co.uk/wp-includes/js/dist/vendor/react.min.js?ver=18.2.0:10:5527) -
is there any caching on the site ?
If so can you clear those caches and then retry accessing the pattern library
