Newsroom – change color of H1
  • I’m using the Newsroom site library, and I’m using the classic editor for posts and pages. I’m unable to change the color of H1 in single posts, and I can see the it’s Generate Blocks that defines H1. How do I change the color of H1?
    the site uses a Block Element found in Appearance Elements called: Single post header
    TIP: When viewing a page you can check the Admin Bar > Elements menu for shortcuts to all elements on that page.
    You will need to edit that element using the Block editor to change its colors.
  • Thanks!
  • You’re welcome
