LimbeekMarketing
Hello guys,
Hopefully I have a question with an easy solution.
I would like to create a web page and set a main page via page attributes. When I look up the page in the search function, the page does not appear. Other pages do appear when I type the first letters.
There are already several pages below this main page (153)
What also strikes me is that the screen settings and help tab at the top right of the screen no longer expands.
Any idea what could be going on?
Thanks in advance!
go to the admin view where the search is not working correctly, and Right Click > Inspect the page to open the Browser Developers tools, look at the Console Tab. Check for errors before and after you try searching or opening the Screen options.
LimbeekMarketing
Hello David,
Thanks for your reply.
I noticed that the Screen options only doesn’t work in the Page tab from WordPress.
Other than that I can not discover anything when I open the Inspect tab in Firefox.I also checked the FlexBlock page attribute function and these errors are presented to me:
MouseEvent.mozPressure is no longer supported. Use PointerEvent.pressure instead. tinymce.min.js:2:8857
MouseEvent.mozInputSource is no longer supported. Use PointerEvent.pointerType instead. tinymce.min.js:2:8857This is abracadabra for me.
When I look at the html of css-selector: #components-form-token-input-combobox-control-2
<input id=”components-form-token-input-combobox-control-2″ type=”text” class=”components-combobox-control__input components-form-token-field__input” autocomplete=”off” role=”combobox” aria-expanded=”true” aria-autocomplete=”list” aria-describedby=”components-form-token-suggestions-howto-combobox-control-2″ value=”” aria-owns=”components-form-token-suggestions-combobox-control-2″>
I notice that the autocomplete is off, is that normal?
It looks to me that some data is limited or not included in the dataset for all the pages.
How do I continue to fix this problem?
I’ve included temporary credentials if you want to take a look.
The action that I do not succeed in are:
For the page: “Gevelbekleding” I would like to set the page attribute: “Gevelrenovatie home” (title) – (url: /gevelrenovatie/) (post_id:19883) – outcome /gevelrenovatie/gevelbekleding/In the WordPress Page area the “Screen Options” and “Help” tab aren’t working.
Hopefully you can take a look and find the problem.
Kind regards,
Robbert
I can take a quick look if you can supply the site URL ?
LimbeekMarketing
Ah sorry, how stupid haha. The url is: https://www.bouwklussen.be/wp-admin
I would recommend disabling all plugins at this moment to debug.
If it’s a live site, I would recommend creating a new staging site and perform the debugging process on it.
LimbeekMarketing
Thanks Ying,
I played with turning off and on different plugins to see when the Screen Options where enabled again. It seems to be a conflict with Fluent Forms, the WPMU DEV plugins and the Yoast duplicate page plugin.
That’s one part of the solution.
Now I would like to know how I can assign the right page attribute to a certain page.
For the page: “Gevelbekleding” (in concept) I would like to set the page attribute: “Gevelrenovatie home” (title) – (url: /gevelrenovatie/) (post_id:19883) – outcome /gevelrenovatie/gevelbekleding/
It is a live site but you have my permission to try and fix the problem if you can. It is driving me crazy 🙂
Thanks for all the help!
Robbert
LimbeekMarketing
Unfortunately the Screen Options and Help Tab froze over again…GRRR…
When I disabled the plugins: Simple Page Order and Page Generator Pro it is working again.
Hopefully it stays ok now.
No luck with the page attributes…
The
gevelrenovatie
does that page exist ?See here :
https://app.screencast.com/J4CEy8THFdCre
I see a list of page starting with
gevelrenovatie
but not on its own.
