dillonloomis13
Why does the pattern library in the backend not include Testimonials and other sections? Whereas when I’m on the GenerateBlocks website under the Pattern library it shows the Testimonials, but I can’t copy it over?
Images for reference:
https://imgur.com/a/5ohzAFt
https://imgur.com/a/WLAJ5IfCan someone please advise? Thank you!
Did you activate the GenerateBlocks Pro plugin? And is it up to date (currently at v1.7 )?
dillonloomis13
Hi Ying,
Thank you for the response. My license is key is entered. How do I know what version I have?
dillonloomis13
Nevermind, I found it. Yes both are active and I have version 1.7
Hum..that’s weird, can try disable all other plugins to see if there was a conflict?
If it still doesn’t work with all other plugins deactivated, can you provide an admin login for us to check the backend?
