Pattern library question
  • Hello, is it possible for this pattern library to put the 5th column on the same line as the other 4? It originally had 4, I duplicated one of them but it puts it on the next line so to speak. There’s no available pattern library templates that have 5 columns. https://imgur.com/a/QvWCLY6
    Is it also possible to set buttons to center? It’s not giving me the option to position them.
    Yes, select the containers nested in the Grid, set width to 20% instead of 25%.
    For the button, select the button and click the add to container button, then select the newly added container, and use the flexbox alignment matrix to align the button.
    Let me know if this helps!
