chrismartin
Hey guys,
I have an issue I’ve not be able to get to the bottom of.
I’ve installed a copy of portfolio and its been running for a while its all up to date etc and I’ve notice if I publish any type of change at the moment the images sizes seem to change in the testimonials section. Has anyone else had this issue? thanks in advance. -
Any chance you can link us to the page in question?
You can use the private information field.
Let me know π
chrismartin
Hey sure thanks for coming back to me
What are the 2 image’s size supposed to be?
chrismartin
Hey Ying, thanks for coming back to me.
The sizes are currently the correct size, however when I make any change and publish it (could just be a content update) The images become really small. I have no idea why this would happen given I don’t make any code changes.
Can you select the image block, and switch it to the GB image block and set the
width
to100%
for the image?
https://docs.generateblocks.com/article/image-overview/To switch from core image block to GB image block, check this video:
https://app.screencast.com/aXAhoyz3aIKsuLet me know if this helps!
chrismartin
So I believe done what you suggested but without any luck. And now I’ve published a change you can see the image size issue. I really don’t know why this is happening and what is creating this change as its pretty much template install wit all the same setttings
There is a
40px
padding in the container that wraps the testimonial image. You can reset that padding using this CSS:.gb-container-7ae1b8b3 > .gb-inside-container, .gb-container-ead3041b > .gb-inside-container { padding: 0; }
chrismartin
Yeah thank you so much for this, I’ll give it a go. π
You’re welcome π
