YEAR93
I’ve added a CTA button to the slide-out menu by using the hook
generate_after_slideout_navigation
. Is it possible to position this button at the bottom of the slide-out menu? If so, how can I achieve this? -
Hello there,
I just looked at your menu, and the button is correctly positioned at the bottom as you wanted. Is that correct?
YEAR93
This is occurring because of the other elements in the slide-out menu, such as the menu and logo, which are pushing the CTA button down. The CTA button starts right after the menu items in the slide-out menu. My intention is for it to always remain fixed at the bottom.
it is possible:
1. add this CSS to the Site:
nav.slideout-navigation .inside-navigation { display: flex; flex-direction: column; height: 100%; align-items: flex-start; justify-content: flex-start; }
What this will do is force the inside container to fill the height of the screen and apply a flex column.
2. Then edit the element hook, and place the CTA button in its own Container block after the other content.
And set its Spacing > Margin Top toauto
You can add padding etc to the Container block -
YEAR93
This worked thank you!
Glad to hear that
YEAR93
I have one more question. Where can I change the color for this element
.slideout-navigation, .slideout-navigation a
customzier > colors > off canvas panel > navigation text.
YEAR93
This works, but it makes the list items white too. That’s not what I want. Only the content below should be white. I’ve added the white color to the button block, but it still remains, instead of ignoring the black color assigned to this class
Can I see the section in question?
YEAR93
Yes, I’m referring to the social icons at the bottom inside the brown section of the slide-out menu when viewed on mobile.
Try adding this CSS:
#generate-slideout-menu .gb-button { color: #fff; }
YEAR93
This worked, thank you! One more question: on mobile, the Safari bottom bar overlaps the information at the bottom of my slide-out menu. Could this be a fix: https://web.dev/blog/viewport-units
Can you provide a screenshot for the issue?
YEAR93
I’ve added screen recording.
Can you try this css?
nav.slideout-navigation .inside-navigation { flex-wrap: nowrap; }
