Post Tempalte has no Equal Height
  • Hallo I have followed the instruction to create equal height but it seems not to work
    Here is the setup https://ibb.co/HtCnJT9
    Can you please help me how you handle that ?
    the issue there is the image is a different aspect ratio, whereas the other images are 1200 x 600, that first image is 1200 x 675px.
    Ideally the best solution is to upload all images of the same size ( aspect ratio ).
    The alternative is to select the Image Block and set a specific Height value eg. 219px and the Object Fit to Cover.
    Which will resize those image to fit… but in doing so the browser may not be able to choose the best responsive size available to it…
