Primary menu loading
  • Upon webpage loading the primary menu typography size appears large and then settles to a smaller size.
    This happens on every single webpage.
    This issue occured since I modified the typography primary menu size from 1.2em to 16px.
    When I reverse the above change, the aberrant loading does not resolve.
    Server, CDN and wordpress cache have been purged.
    Problem still persists.
    I wonder whether global settings from typography have any bugs as this happened previously when setting <H2> settings (no deleted)
  • It’s likely caused by your cache plugin, try disable the cache plugin clear cache and re-test again.
