AbsaWeb
I am using this and it works in your theme, but it only shows me the author, the author image with some plugins, but not with others.
// Generate author image and link in separate containers add_filter( 'generate_post_author_output', function() { return sprintf( ' <div class="author vcard">%4$s</div><div class="author-wrap"><span class="label">Escrito por:</span><a href="%1$s" title="%2$s" rel="author"><span class="author-name" itemprop="name">%3$s</span></a></div>', esc_url( get_author_posts_url( get_the_author_meta( 'ID' ) ) ), esc_attr( sprintf( __( 'View all posts by %s', 'generatepress' ), get_the_author() ) ), esc_html( get_the_author() ), get_avatar( get_the_author_meta( 'ID' ) ) ); } ); // Filter meta items to display date and author add_filter( 'generate_header_entry_meta_items', function() { return array( 'author', 'date', 'social-icons', ); } );
For example, it is compatible with Yoast, Rank, but not other SEO plugins.
Thanks.
What do you want it to show?
AbsaWeb
Author, author image, author tittle.
Thanks.
Where are the author image and author title from?
AbsaWeb
Post or page.
With Yoast, Rank is ok, but with ohter plugins not show.
As we don’t know how other plugins are adding those author metas.
You will need to reach out to the plugin’s support and ask them how to pull the author image and author title, then we can integrate their code to your current code.
