Afonso Alves
Good morning, how can I make the footer line full width as shown in this example: https://prnt.sc/ykpO7juwUunx
Right now mine looks like this on the desktop: https://prnt.sc/CzpVPr73prih
I await directions.
Anovatis
hi Alfonso, how did you create your footer line? widget, GP footer element?
If you used the block editor, you should be able to add a GB grid of 2 column and split the text accordingly. -
can you share a link to the site where we can see the layout.
Afonso Alves
Yes check link in private information
Edit your footer element.
The layout looks like this:Container Block #1 <- Full Width Container ---- Container Block #2 <- has Sizing > Max Width ---- ---- Grid Block ---- ---- Container Block #3 <- the footer bar
You want the Container Block #3 to be a child of Container Block #1 so its not limited by the Max Width
Drag Container Block #3 so it becomes a child of #1.
The layout will look like:Container Block #1 <- Full Width Container ---- Container Block #2 <- has Sizing > Max Width ---- ---- Grid Block ---- Container Block #3 <- the footer bar
Afonso Alves
Good morning,
I made this change now but it looks like this: https://prnt.sc/Qwsd1dI1pahP
How can I leave it with the desired result?
screenshot of the structure: https://prnt.sc/_3Xpba56iIem
Afonso Alves
I updated website on private information
Afonso Alves
check
Container Block #1 – add some Spacing > Padding.
Container Block #2 – adjust the Sizing > Max Width value if required, first uncheck the global option -
Afonso Alves
After following the instructions I still wasn’t able to achieve the desired result: https://prnt.sc/Qz-3kb_P-cmV
At the moment it looks like this: https://prnt.sc/qLJmCRUMCUTX
Referencing this:
Container Block #3, set its:
Sizing > Max Width to the value to need eg. 1200px
Spacing > Left Margin & Right Margin toauto
to center.Adjust your Max Width and Padding values to suit.
Afonso Alves
I made these changes but it seems that the footer is still a little different from the intended result.
Can you explain what needs changing ?
