yun22222
I use generateblocks query loop, but when I click on the link, it doesn’t open in a new window. Is there a taget blank option?
If not, is there a way to make only the generateblocks query loop link open in a new window?
1. Add this PHP Snippet to your site:
add_filter( 'render_block', function( $block_content, $block ) { if ( !is_admin() && ! empty( $block['attrs']['className'] ) && strpos( $block['attrs']['className'], 'open-in-new-tab' ) !== false ) { $myreplace = '<a'; $myinsert = '<a target="_blank" '; $block_content = str_replace( $myreplace, $myinsert , $block_content ); } return $block_content; }, 10, 2 );
2. select the block with the dynamic link and in Advanced > Additional CSS Classes add:
open-in-new-tab
danstramer
Hi David,
Any chance this will be added via the UI?Dan
yes, its on our list of to dos.
Once have the latest alphas out the way we will be revisiting legacy features requests such as this. -
danstramer
Great, thanks!
You’re welcome
