Alexis822
I have created a query loop with grids. 5 customer cases per grid. The second grid has no image for the moment. But it creates a space. How to remove it when it is empty
Have you resolved the issue?
Just checked the linked page and don’t see any odd space.
Alexis822
Check HTML after : “Cabinet d’expertise comptable et conseil pour les entreprises” please
“gb-grid-wrapper gb-grid-wrapper-ed3511d3 grid-portfolio”
Hi Alexis,
Are you referring to having the same height for Grid columns? If so, you can check this Article out: https://docs.generateblocks.com/article/equal-height-grid-containers/
Alexis822
No, in fact below the 5 client cases, there is an empty space because I recreated a grid with query loops. But for the moment there is nothing. But it creates a gap. Look above the section “Trust us with your digital strategy!”
To assure we’re seeing the same thing, can you share a screenshot of the issue from your end?
Uploading Screenshots: https://docs.generatepress.com/article/using-the-premium-support-forum/#uploading-screenshots
Alexis822
I have another need also related to the query loop. Can we display a custom message when it is empty
The space is coming from the padding set. Try moving the padding to the Post Template Block of the Query Loop instead.
Can you open a new topic regarding the other inquiry?
Alexis822
So there is no solution for this div not to appear as long as there is nothing in the query loop
Try adding the padding to the Post Template Block and add this CSS:
.gb-grid-wrapper.grid-portfolio .gb-query-loop-wrapper:empty{ display:none; }
Alexis822
I still have the spacing
the spacing is coming from the grid item containers that each of your empty query loop items are inside of.
and theres no simple way to tell a container block to do something if the query item inside of it is empty.Question – why use a Grid Block with so many individual Query Loop blocks ?
Alexis822
Ok, The images are never the same size. Out of the 5 cases.
Can you use a single query Loop block to show ALL the posts, and then we can look at how to change the sizes.
Alexis822
To do in css ? I’ll tell you that I spent a lot more time on this project and I’m not finished yet. But for the next times I will do like this if it is recommended
If you wanted to show a layout like this for example:
Post 1 | Post 2 --- Post 3 --- Post 4 | Post 5 --- Post 6 --- Post 7 | Post 8
Then you can make a Query Loop, and set the Post Template -> Sizing -> Width to
50%
We can then use a couple of lines of CSS to make Post 3 and Post 6 100% Wide.
Is that what you need ?
