carlom
I have both GB pro and GP premium.
I have created a query loop and I’d like to set the parameters to order the quey loop output by an ACF custom field “idordine” (it’s a text custom field).
I cannot see the right parameters to set.
How can I do that?
Thank you.
I believe this article should help:
https://docs.generateblocks.com/article/order-query-loop-by-custom-field/Let me know 🙂
carlom
Hi Leo,
thank you. I managed to order the query loop according to the custom field.
Now, I would like to filter another query loop by another custom field:I have a custom field called “highlighted”.
It was created in ACF and it’s a “true/false” field.
I want to filter the pages that have the “highlighted” field set to true.I tried some code that I found on this forum, but it’s not working.
here’s an example I have tried with no success:
add_filter( 'generateblocks_query_loop_args', function( $query_args, $attributes ) { // Check your logic to apply the filtering only to specific loop if ( ! empty( $attributes['className'] ) && strpos( $attributes['className'], 'testsliderfield' ) !== false && is_home() && ! is_admin() ) { // Merge the current $query_args which contains arguments defined in the editor with your ordering arguments return array_merge( $query_args, array( 'meta_query' => array( array( 'key' => 'highlighted', 'value' => '1', 'compare' => '==' ) ), ) ); } return $query_args; }, 10, 2 );
See the url in private information window.
What am I missing?
Thank you.
Hi Carlom,
Try removing the Quotation marks for
1
.Example:
'value' => 1,
carlom
Hi Fernando,
I have just tried but it is still not working
your snippet includes the
is_home() &&
condition, if its not your home page then remove that condtion. -
carlom
Hi David,
you are right, I haven’t noticed that condition in the code I copied!
Now it works.
The code I am using is now this one:
add_filter( 'generateblocks_query_loop_args', function( $query_args, $attributes ) { // apply filter if loop has class: orderby-acf-idordine if (! empty( $attributes['className'] ) && strpos( $attributes['className'], 'orderby-acf-idordine' ) !== false) { return array_merge( $query_args, array( 'meta_key' => 'highlighted', 'meta_value' => '1', 'compare' => '==' )); } return $query_args; }, 10, 2 );
How can I add the code to order by “idordine” field all the post that have “highlighted” = 1?
I mean, how to combine the code above with this one in order to order by “idordine” field all the post that have “highlighted” = 1?
add_filter( 'generateblocks_query_loop_args', function( $query_args, $attributes ) { // apply filter if loop has class: orderby-acf-idordine if (! empty( $attributes['className'] ) && strpos( $attributes['className'], 'orderby-acf-idordine' ) !== false) { return array_merge( $query_args, array( 'meta_key' => 'idordine', 'orderby' => 'meta_value', 'order' => 'ASC', )); } return $query_args; }, 10, 2 );
Not 100% sure but you can try this:
add_filter( 'generateblocks_query_loop_args', function( $query_args, $attributes ) { if (! empty( $attributes['className'] ) && strpos( $attributes['className'], 'orderby-acf-idordine' ) !== false) { return array_merge( $query_args, array( 'meta_query' => array( array( 'key' => 'highlighted', 'value' => '1', 'compare' => '=' ) ), 'orderby' => 'meta_value_num', 'meta_key' => 'idordine', 'order' => 'ASC' )); } return $query_args; }, 10, 2 );
carlom
Hi David,
thank you, it works.This is the exact code that is working for me:
add_filter( 'generateblocks_query_loop_args', function( $query_args, $attributes ) { if (! empty( $attributes['className'] ) && strpos( $attributes['className'], 'orderby-acf-idordine' ) !== false) { return array_merge( $query_args, array( 'meta_query' => array( array( 'key' => 'highlighted', 'value' => '1', 'compare' => '=' ) ), 'meta_key' => 'idordine', 'orderby' => 'meta_value', 'order' => 'ASC' )); } return $query_args;
Glad to be of help
