ashokvas
I am trying to create a Latest post element which shows the latest 8 posts at the bottom of a post.
I have used a Query loop grid
I want to show the posts based on the last modified date in a descending order
I DO NOT want to sort based on published date , as we keep on updating our posts
I cant seem to display the latest modified post at the top in descending order.
In the query loop settings, I tried to order by “Last modified date” but it is not working properly.
You can see the “Latest Post” element in my admin panel
I checked one post, but I did not see a GB query loop block.
I saw the Read next section, is this what you referring to? If so, the block is not from GB, we do not have control over it.
https://app.screencast.com/LMVMb2yaQbtRPLet me know if I miss anything!
ashokvas
Please login to my admin ( I have given the login details )
Go to Elements>> Latest Post
This is the block with query loop.
I have sorted by Last modified
in the Query Loop add a Parameter:
ORDER
and set that to DESCENDING -
ashokvas
I have set it as shown in screenshot
But it is not working properly
see the posts at the bottom of the page
https://www.smartbabyadvice.com/home/
They are not showing last modified descending order
In your screenshot you have a Query Parameter of Post Status that has not value. Can you delete that parameter.
ashokvas
I removed it
https://imgur.com/x15DgArstill not working properly
ashokvas
I changed the order by to “Date” and it is working fine now
Glad to hear that
ashokvas
ashokvas
I am using the above Related post element on my Home page, but I want to use one on my Posts as well
I want to ensure that the current post does not display in the list of related posts.
I cant see how to do that?
Do I need to build a different element for this? Or can I use the same one as I am using for my home page.
Also should the Related posts grid show after or before the author box?
How do I position these ( by Priority ?)
It requires GB Pro plugin to add Exclude posts parameter and select the current post.
Which hook are you using? if you are happy with the hook on post, then you can use the same element, just add
posts > all posts
to the location along with your homepage.How do I position these ( by Priority ?)
If they share the same hook, then yes, you can use priority to arrange the order.
