psrios
Hi guys, I hope you are all doing great!
I have this site here in which there the “trending now” div (on the right) I would like to change the query loop to display random posts instead of the latest posts. How can I do it? many thanks! the site link is posted below
To randomly order the posts is a GB Pro feature.
If you have GB pro, you can add
order random
parameter. -
psrios
i dont have pro :/
psrios
I found this thread, if I add this code, would I be able to have it working? thanks
https://wordpress.org/support/topic/query-loop-random-selection-of-posts/
Yes, that’s the right code, and you need to add the class
my-class-name
to the Grid block of the query loop.You can change the class to anything else, just make sure they match.
psrios
I will try out thank you!
psrios
Hi Ying,
How exaclty do I use it? I know how to add the PHP code, and add the class my-class-name to the Grid block of the query loop, but then is there any other step? thank you
psrios
it returns the following error
Your PHP code changes were not applied due to an error on line 22 of file wp-content/themes/generatepress_child/functions.php. Please fix and try saving again.
syntax error, unexpected token “)”
psrios
Hi Ying, good news it is working now thank you! have a lovely day!
psrios
ah just another question, how can i exclude some categories for example, I can see featuring Halloween posts as it is not Halloween id like to exclude them for the moment =) thank you!
You can add an exclude parameter to exclude a taxonomy in your Query Loop.
Your code shouldn’t override that parameter. It should just append the parameter.
psrios
Hi Fernando!perfect! Thank you all, guys. Great work!
You’re welcome!
