EricBlair
1. What is the recommended way of assigning separate images (large/small, landscape/portrait) to hero images with GeneratePress?
2. And would this differ substantially for other large images elsewhere on the site?
I’ve read in the documentation that for GP hero images it’s recommended to use the page-hero block element, but I’m not sure this way is more user friendly than just writing raw CSS. And this this then confuses me for how to add a srcset.
Can someone please break down the recommended way of doing this is. Thank you.
background images are added using CSS, so there is no
srcset
or other image meta ( such as its orientation ) to work with.But there are some workarounds, if the image was loaded dynamically.
Would the hero background image be the featured image of the page ? -
EricBlair
In this particular case I’m just looking to place two large images on the homepage – one above the fold, and the other much further down the homepage. Each of which won’t really work for phone and tablets. So I also have portrait versions for each, in addition to landscape versions. Therefore, I guess I don’t really mind how it’s applied (featured image, or otherwise) if that’s what you’re asking. Except that I need to do this twice on the page, and featured image only defines one, correct? So I’m not sure that’s the way I should go. Please advise.
I didn’t know CSS was capable of adding images. Is this something I need to learn how GP is doing this?
I would like to think I’m more than a beginner with HTML, CSS, PHP; but I only know enough to know that I’m definitely not an expert. I am also constantly taking courses on things, so feel free to suggest ideas to me.
Currently, I’m learning my way around Dreamweaver, and I’m curious if it’s easier just to copy ‘page.php’ and create ‘front-page.php’ and make my own responsive homepage? Or do these features of GP Premium you speak of for hero images etc. make my idea more trouble than it’s worth?
What’s the suggested way to serve two different, viewport-dependant versions of an image (the intermediate-level WordPress user method(s)? Thank you.
It is not worth the trouble.
Using the block element – page hero is indeed more user friendly. As you can change the images with in the UI without touch CSS.
In this particular case I’m just looking to place two large images on the homepage that won’t really work for phone and tablets. So I guess I don’t really mind how it’s applied (featured image, or otherwise) if that’s what you’re asking.
You can add two image block to the block element – page hero. what will the layout be? Two images side by side or be stacked?
EricBlair
Rephrase: two instances on one page, where I will need to serve landscape vs portrait versions for each; depending on the viewport.
This means, as far as I knew, a srcset of at least two images, per instance this situation occurs on the page (twice).
I don’t want to confuse the thread about the two instances, because whatever the process is for one, I will do the same for the other.
The real two images in question are the landscape and portrait versions that will essentially need to occupy the same block; and the browser will choose between them based on the width of the viewport.
I thought this was a common enough situation, no? Why do I get the feeling I’m the first person to ever ask it? Seems odd…
WP generates different sizes of image when you upload an image to media library, and WP chooses the image srcset based on the image size and view port width.
The default srcset WP generates are Thumbnail, Medium, Large, you can change the width/height for each size at settings > media.
Hopefully it generates the size you want, and WP will automatically choose the most fit size based on screen sizes.
But be note, the setting will apply to all images.
If you just want the two specific images to have this setting, it might be easier to use background image, and use CSS to change the background image to portrait version on mobile.
EricBlair
Please correct me if I’m wrong… are you claiming that:
1. The majority of people who use the page hero block element are fine with serving a landscape version of their hero image for mobile users, so long as WP crops it? It sounds like that’s what you’re claiming.
…it might be easier to use background image, and use CSS to change the background image to portrait version on mobile.
2.Are you essentially telling me to buy the Pro version of GenerateBlocks? It sounds like that’s what you are saying, without actually saying it, which then prompts me to have to type in here again to get a straight answer… Is this what you’re claiming? And if so, why wouldn’t you simply state that is the recommendation??
3. Why do you state in your documentation that you recommend people use the page hero block element for page hero images, when the element you suggest is insufficient for the main task most people use a hero image for? Why do you do that? Which then forces many days of wasted time trying to figure out how to do something that used to be easy with simple HTML and CSS? Why make it more difficult with every iteration? And why send people down rabbit holes, especially when this is most likely one of the most common questions you get, I would assume.
4. Why is there no direct documentation at the very beginning of the docs that deal with this most common of issues? You would think that with something so common, not only would you state at the top of the docs for page hero element, that it’s insufficient for what most people would want it for (step 1), but one would think you would also make a dedicated page to explain for people how to do the one task that I would expect every website owner has to deal with, unless they give zero f’s about their images… which it sounds like the recommendation here is (just use the WP cropped images and hope it works?? wtf?)
5. How is this easier than building my own theme in dreamweaver? What’s the point of purchasing this again? I forget…
EricBlair
Thank you David. Do you care to share these workarounds? Or do I need to ask a special way?
The Hero image, will it have any content overlaying the image ?
EricBlair
If I answer this question directly, will it be answered by another question?? Thereby forcing another day waiting for an answer (aka another question)?
How about this: how many hero images can you think of that wouldn’t have content overlaying the image? Give a percentage — try it… (then ask yourself how relevant is the question you just posed?)
Or how about this: rather than asking the question, why not give a clue for both situations?????????? Rather than wasting another day?
Good grief…
EricBlair
Good grief…
I would say from my many years experience of helping several thousand users and having viewed at least as many thousands of sites, in the context of support, design and development, i would guess at least 20-30% of hero sections don’t have content over the images.
It’s generally a good design decision to not overlay content if the image is important content and not just for presentation.As to your request, although you may feel is a commonly asked question and a super common modern web design requirement, i can say from my experience that this is not a common requirement at all. And it comes with several complications that need to be considered.
Ask yourself this – is it the image that will define the aspect ratio of the Hero, or is it the content that sits over the image ? Its a hypothetical question btw, but it will most probably become really relevant at a later point.
So to build a Page Hero:
1. Storing a separate Portrait image
WP doesn’t provide this as a built in option. So it will require you to add a Custom Field to store the portrait images in the single post meta.Of the many ways to adding custom fields, the easiest is to use the ACF plugin.
It does a lot of the grunt work and has a nice UI.https://wordpress.org/plugins/advanced-custom-fields/
2. Adding the custom fields:
Add the ACF plugin, and in its settings you can create a Field Group for your Posts.
2.1 add a new Field for the Portrait Image.
2.1.1 Give it a name eg.Post Portrait Image
2.1.2 And make a note of the Field name eg.post_portrait_image
2.1.3 Set the Return Value toImage ID
2.1.4 Set the Rule to Display on All postsSee here for reference:
https://app.screencast.com/hOtagGWrzkGs6Once that is done you should see the Portrait Field Option in your single Post.
3. Adding the images.
In your single post use the Featured Image to add your Landscape Image.
By using the featured image for this, that image can be used on any archive pages or elsewhere eg. an SEO plugin needs it for its OpenGraph Meta.
Then add the Portrait image to your new Custom Field.4. Create the Page Hero using a Block element.
For this you will require the FREE version of the GenerateBlocks plugin:
https://wordpress.org/plugins/generateblocks/4.1 Appearance > GeneratePress, activate the Elements Module:
4.2 in Appearance > Elements -> Add New -> Block
4.2.1 In the element settings sidebar choose thePage Hero
https://docs.generatepress.com/article/block-element-page-hero/
4.2.2 And set its Display Rules
then you can build your hero inside the block element
5. Building the hero
whilst in the element editor open the List View just for reference:
https://wordpress.org/documentation/article/list-view/Using GenerateBlocks you will create the following layout starting with a Container Block and the GB Blocks inside:
Container Block #1 ---- GB Image Block #1 ---- GB Image Block #2 ---- Container Block #2 ---- ---- GB Headline Blocks for your overlay content
Container Block #1
In Advanced > Additional CSS Class(es) add:custom-hero
Container Block #2
In Advanced > Additional CSS Class(es) add:custom-hero-content
GB Image Block #1 & GB Image Block #2
https://docs.generateblocks.com/article/image-overview/
All GB blocks have dynamic data built in – see here:https://docs.generateblocks.com/article/dynamic-data-options-overview/
For both blocks you will enabled the Dynamic Data
Image Block #1 will have its Image Source set toFeatured Image
Image Block #2 will have its Image Source set toPost Meta
and in the field provided add your custom field name ( see 2.1.2 ) eg.post_portrait_image
You can use GB Headline Block and its dynamic data to display content such as the Post Title.Once all blocks are set Publish the Element.
6. the Hero HTML and custom CSS
At this stage you’re single post hero will return the following ( simplified version of ) HTML:<div class="custom-hero"> <figure><img landscape></img></figure> <figure><img portrait></img></figure> <div class="custom-hero-content"> .... other blocks here </div> </div>
Now it require some CSS:
6.1 Absolute position the
custom-hero-content
over the hero:.custom-hero { position: relative; } .custom-hero-content { position: absolute; inset: 0; z-index: 1; }
6.2 Show / Hide the relevant image
/* if the orientation is landscape hide the portrait img */ @media (orientation: landscape) { .custom-hero figure:nth-child(2) { display: none; } } /* if the orientation is portrait hide the landscape img */ @media (orientation: portrait) { .custom-hero figure:nth-child(1) { display: none; } }
The CSS may need some tweaking but the rest of the responsive behaviour can be handled using the settings on each of the GenerateBlocks.
I hope that helps
EricBlair
Now that is a very comprehensive and professional answer. Thank you.
Please correct me if I’m wrong here:
1. By using the featured-image as the backbone of this strategy, if I go through all this, then I still will only be able to do it once per page, correct?
Meaning every other image on the page should either be:
a) small enough to see normally on a cell phone;
b) irrelevant enough to crop most of it off.Am I incorrect in assuming these things?
2. And if this is correct, is the next, most feasible option –to pay rent to GB Blocks Pro forever, for this single feature of serving images dynamically? (Am I even correct in assuming that GBPro does this?)
that is correct.
Although it would be possible to modify the above if necessary to use elsewhere on the page using more custom fields.However if there were no overlay requirements then simply use a Image Block to display the image.
And if you wanted to have variant for landscape and portrait images then:i). Add this CSS to your site:
/* if the orientation is landscape hide the portrait img */ @media (orientation: landscape) { .is-portrait { display: none !important; } } /* if the orientation is portrait hide the landscape img */ @media (orientation: portrait) { .is-landscape { display: none; } }
ii) Add a block each for the Landscape and Portrait variants.
And in the blocks settings Advance > Additional CSS Class(es) field, you can attribute a CSS Class to the blocks HTML. Here you can addis-portrait
oris-landscape
depending on the image orientation.2. GenerateBlocks Pro, currently provides a method of swapping ONLY static CSS background images based on different screen-sizes, and considering your specific requirements this would not be a good solution in my opinion.
