willamato
Hello
Ive designed a site that uses a background image in the menu bar to create a kind of fake bezel
Is there a way to remove the background image in the drop-down menu, and instead have, say, a light greybackground color?
Thank you, and thanks for a great theme!
W
You don’t need to use a background image in this case, you can remove the CSS which adds the background image.
Then add this CSS for the gradient effect for the menu toggle:
button.menu-toggle { background-image: linear-gradient(180deg, rgba(255,255,255,1) 0%, rgba(186,186,186,0.5830926120448179) 100%); }
And this CSS for the menu items, feel free to change the color.
#primary-menu ul#menu-main { background-color: rgba(0,0,0,0.3); }
This tool should be very useful to create CSS for gradient:https://cssgradient.io/
Let me know if this helps!
willamato
Thats fantastic, and something I’ll use again. Thank you, Ying!
