wrigh7y
I have a container, inside is a label (Headline) and another headline field that contains dynamic data (Post date – updated).
I want to hide this container if there is no “updated date”. But in order to use the REMOVE CONTAINER CONDITION in the block settings, I need to know the META FIELD NAME.
Does anyone know the meta field name for the updated date? Or if there is a document that lists all the meta field names so i dont need to ask again in the future.
Chris -
the dates are not saved in Post Meta, so there is no field to check for.
Instead you could use a PHP Snippet with therender_block
hook to remove a Container Block with a specific class if there is a) no modified date or b) the modified date is the same as the published date.Here is the PHP Snippet:
add_filter( 'render_block_generateblocks/container', function( $block_content, $block ) { if ( ! is_admin() && ! empty( $block['attrs']['className'] ) && strpos( $block['attrs']['className'], 'post-updated' ) !== false ) { $post_modified_date = get_the_modified_date(); $post_published_date = get_the_date(); if ( ! ( $post_modified_date && $post_modified_date !== $post_published_date ) ) { $block_content = ''; } } return $block_content; }, 10, 2 );
Then select the Container Block, in Advanced > Additional CSS Classes add:
updated-date-container
wrigh7y
Thanks David, thats great!
wrigh7y
Could be me but it seems to be doing the opposite. Removing the block if it DOES have a date. Keeping it if it doesnt.
Oh my – having a logic overload today. I updated the code above, give that a shot.
wrigh7y
We all have those days lol.
Page doesnt seem to want to load using the new one. Just get a blank screen until I remove the Additional CSS Class.
I tried clearing my browser cache and also purged my hosting cache.
EDIT: Managed to sort it. It was the is_empty
add_filter( 'render_block_generateblocks/container', function( $block_content, $block ) { global $post; if ( ! is_admin() && ! empty( $block['attrs']['className'] ) && strpos( $block['attrs']['className'], 'updated-date-container' ) !== false ) { $post_modified_date = get_the_modified_date( '', $post->ID ); $post_published_date = get_the_date( '', $post->ID ); if ( empty( $post_modified_date ) || $post_modified_date === $post_published_date ) { $block_content = ''; } } return $block_content; }, 10, 2 );
Right thats it – i am going back to bed lol
I did just correct the code above in case… but i am glad to hear you got it working! -
wrigh7y
Hahaha we got there in the end!
Thanks again.
You’re welcome 🙂
