MattGP
Hi, is there a way to remove the default button padding?
The reason is that I use Global Styles for my buttons. (I know I can press the “clear local styles” button, but I was hoping we could avoid that step for a simple button.)
I’ve tried using this filter:
add_filter( 'generateblocks_defaults', function( $defaults ) { $color_settings = wp_parse_args( get_option( 'generate_settings', array() ), generate_get_color_defaults() ); $defaults['button']['paddingTop'] = ''; $defaults['button']['paddingRight'] = ''; $defaults['button']['paddingBottom'] = ''; $defaults['button']['paddingLeft'] = ''; return $defaults; } );
But that didn’t work since GenerateBlocks doesn’t accept empty values:
'spacing' => [ 'paddingTop' => $defaults['button']['paddingTop'] ? $defaults['button']['paddingTop'] : '15px', 'paddingRight' => $defaults['button']['paddingRight'] ? $defaults['button']['paddingRight'] : '20px', 'paddingBottom' => $defaults['button']['paddingBottom'] ? $defaults['button']['paddingBottom'] : '15px', 'paddingLeft' => $defaults['button']['paddingLeft'] ? $defaults['button']['paddingLeft'] : '20px', ]
(Source: generateblocks/includes/defaults.php)
Is there another way to remove the default padding-values?
Thank you!
the fields accept non-numeric unit values. So you could use that filter to set them all to
initial
MattGP
Thanks for your fast reply!
Changing the value to initial did remove the padding, but I couldn’t override this value with the padding-settings from my own Custom Style.
(I just noticed that the title of my thread should have been “Override default button-padding with Custom Style”).
As a workaround, I’ve created a CSS-variable with the same padding-values as in my Custom Style:
add_filter( 'generateblocks_defaults', function( $defaults ) { $defaults['button']['paddingTop'] = 'var(--button-padding)'; $defaults['button']['paddingRight'] = 'var(--button-padding)'; $defaults['button']['paddingBottom'] = 'var(--button-padding)'; $defaults['button']['paddingLeft'] = 'var(--button-padding)'; return $defaults; } );
It’s not perfect but it does the job for now 🙂
If you’re using a custom style, then i would say that probably is the perfect way 🙂
Glad to hear you got it working.
