Remove internal nofollow in comments
  • Anfisa Sobchak
    Hello!
    How to remove nofollow from internal link?
    The rel=”nofollow” attribute is an element in an tag that tells crawlers not to follow the link (e.g., “Nofollow link example”).”Nofollow” links don’t pass any link juice to referred webpages. That’s why it is not recommended that you use nofollow attributes in internal links. You should let link juice flow freely throughout your website. Moreover, unintentional use of nofollow attributes may result in your webpage being ignored by search engine crawlers even if it contains a valuable content.
    Best Regards
    Anfisa
  • Hi Anfisa,
    The comment area is handled by WordPress, GP doesn’t have control over the attributes you mentioned. You can test with Twenty-twenty series themes, the markup should be the same.
    I would recommend reaching out to WordPress’s support.
