Stefan
But i don’t get it to work:
class, owd-fade-in
.own-fade-in { animation: owd-fade-in linear forwards; animation-timeline: view (); animation-range: entry; } @keyframes owd-fade-in { 0% { opacity: 0; transform: translatey(480px) } 50% { opacity: 0; } 100% { opacity: 1; transform: translatey(0px) } } }
And I see in the customizer this parts in red,
animation-timeline:
animation-range:why is this happen?
Thanks -
The Customizer > Additional CSS field in WordPress only parses CSS that is Level 2 or below. So perfectly valid CSS that is of Level 3 will get flagged red.
The issue here will be a Animation on Scroll requires Javascript. Do you have the script that accompanies that CSS?
Stefan
The CSS
animation-timeline
API has limited browser support – see here:https://caniuse.com/?search=animation-timeline
So you need to be careful in using them as on the unsupported browsers you may end with elements being hidden.
For that reason I would recommend using a JS solution.
Stefan
Thanks David, you have a script with java in hand?
Thanks -
George, one of our designers, provided this tutorial:
And it uses a lightweight JS framework
Stefan
Hi David,
Thanks a LOT!.
Followed this
But it won’t initialize, the script, is all uploaded, see the images below;And in the source code, I can see the files, but not at the Advances attributes, the options to change.
Regards
Are links not showing? here again
https://ibb.co/gSjjTN9
https://ibb.co/QQ3jX3Q
https://ibb.co/djSxk4G
https://ibb.co/104gYTG -
You need GenerateBlocks Pro to use the custom Attributes feature.
Dear Fernandos,
It works with the Plugin “Attributes for Blocks By websevendev” too.Thank you and Thanks David for the idea with SAL from mciastek.
Regards -
I see. You’re welcome!
