techbackend04
I have my search icon on the right corner of the header. When we click on the search icon, I want a small box expanding on its left to enter the text.
sample below
https://imgur.com/irErpi1Thanks,
You might want to use the legacy navigation search of GP in this case.
1. go to customizer > layout > primary navigation, disablenavigation search modal
.2. add this PHP and activate it:
add_filter( 'option_generate_settings', function( $settings ) { $settings['nav_search'] = 'enable'; return $settings; } );
3. go to customizer > layout > primary navigation, and enable
navigation search
.once it’s done, you will need some CSS to style the search field, let me know!
techbackend04
Appreciate your prompt response.
It works. Is it possible to provide me CSS style code to reduce the search box, round the corners, and change background and text colour.Thanks a lot.
The CSS would need to be customized depending on the site’s nav layout, can you link us to your site?
techbackend04
Below is the site.
Thanks,
Try this CSS:
.navigation-search input[type="search"] { max-width: 50%; border-radius: 20px; background-color: #fff; border: 1px solid pink; opacity: 1; } .navigation-search.nav-search-active { text-align: right; } .navigation-search :is(input[type="search"], input[type="search"]:active, input[type="search"]:focus) { color: #000; }
techbackend04
Hello Ying,
Awesome. It works. If you don’t mind can you please add the text colour as black.
Thanks,
I added the CSS here: https://generate.support/topic/search-icon-expansion-in-header-itself/#post-104103
techbackend04
Thank you so much. You are awesome. Good luck.
