Is there any good tutorial where I can learn how to setup secondary navigation?
you can read the related docs here:
https://docs.generatepress.com/article/secondary-navigation-layout-overview/
Let me know if theres something specific you need.
I want to add a simple secondary menu on top of the primary menu but since I am a beginner I am having a very hard time figuring things out.
OK.
1. Go to Appearance > GeneratePress, and activate the Secondary Navigation module.
2. Go to Appearance > Menus
2.1 Add New Menu, and add your menu items
There’s a really good doc here on using the Menu builder
2.2 set the Menu Location to the Secondary Navigation3. Go to Appearance > Customizer -> Layout -> Secondary Navigation.
here you can set its Location and other layout styles -
Thank You for the reply David. I will give it a try.
You’re welcome
