airbag41
I’m having a trouble with a shortcode from the plugin ad inserter.
If I place the shortcode on a page it returns nothing, yet if I use a shortcode for another plugin, such as the WP Show Posts plugin, the shortcode does work on a page.So it would seem something is causing the ad inserter plugin short codes not to work. Just taking a shot to see if anyone else has run in to this issue or if somehow it is being blocked from running.
Hi Airbag,
For one, you can first try disabling plugins to test if a plugin is causing it not to work.
You can also try temporarily using a different theme to see if it’s a theme conflict issue.
It would be ideal to first reach out to this plugin first for any insights regarding the issue.
airbag41
Ok thanks
You’re welcome, Airbag!
