Pintu Biswas
Hi there, When I’m adding 3 images to Gallary, on mobile the first two images are showing side by side, and the third one showing in full size, separately. https://postimg.cc/Y4SJFHhy
I want all the 3 images to be side by side on mobile. How do I do that?
Page URL: https://geekcrave.com/uninstall-bixby-using-adb (Scroll down a little you’ll see the gallery)
Thanks.
you can force the default 3 column gallery to remain 3 columns with this CSS:
.wp-block-gallery.columns-default { display: grid !important; grid-template-columns: repeat(3, 1fr); } .wp-block-gallery.columns-default > .wp-block-image { width: 100% !important; }
For galleries where you don’t have 3 images, and you want them to continue to fill the row, you will need to change the columns count in the gallery block settings.
Pintu Biswas
Hi this CSS works as I wanted for 3 images gallery.
However, the 2 image gallery creates a space after the second image on the mobile device.
See here: https://postimg.cc/4YfrNqM8
Kindly tell me how to fix this.
referencing my reply above:
ie. change the Gallery Block settings to 2 columns
Pintu Biswas
It is already set to 2. https://postimg.cc/CZR1TH2P
Also, I don’t think you can set 3 columns when you’ve only 2 images in the Gallery.
Ah sorry, my bad.
I should of expected the WordPress CSS to be terrible lolAdd this CSS to make a 2 column gallery into 2 columns:
.wp-block-gallery.columns-default.wp-block-gallery-2 { grid-template-columns: repeat(2, 1fr); }
Pintu Biswas
Hi David, adding this CSS
.wp-block-gallery.is-layout-flex { flex-wrap: unset; }
finally fixed my problem.
Glad to hear that
Just beware if you have A LOT of images in the gallery they will all try and stay on the one line…. -
Pintu Biswas
I see…
But this is the best solution for right now for my needs.
I wish WordPress Gallery had a built-in control for this. To me, the Gallery Block right now is very limited.
Also, will there be a Gallery Block from GB anytime soon? That’d be awesome.
We have plans for mare advanced galleries that use query loops.
Theres a feature request open for it in the feedback , if you want to add your vote:
