jetsetandforget
This is probably a simple fix but I can’t find it on the forum or google. the author name used to show on each blogpost before I changed to generate press. I just need the name, no image, nothing fancy. I only have two authors.
How can I get it to show again? I poked around all over the theme and word press and I can’t seem to find it. thanks!
Can I see one of your post so that I can suggest based on your post structure?
jetsetandforget
https://www.jetsetandforget.com/springs-preserve-las-vegas/
I think it used to be near the date at the top
You can enable it at customizer > layout > blog > content > single > Display post author.
jetsetandforget
ah single! The one step I skipped, I knew it was somewhere, thank you!!!
