Is it possible to get the left sidebar to the top of the page, so also to the left next to the header
Not sure if I fully understand.
Can you show an example of what you are trying to achieve?
Hi Leo,
See this image. My website should show this flower at the left side from top to bottum.
Thanks for your reply.
I’m looking forward to your answer.https://taokosmetiekjeanny.nl/wp-content/uploads/2023/05/2023-05-16-12-13-42.png
is it just the flower image you want positioned there ?
If so it may be simpler to add the image in a different way.Would it be possible to see your website with the image in the sidebar so i can consider some options ?
Hi David,
If your solution is just like the image, it is oké with me.
Greetings
Thijs -
Can you share the page link with the image in the sidebar as David asked? Let me know!
Hi Ying
Unfortunaly there is no link to a website because it is in progress.
This is the link to a document which shows how the webpage should be.https://taokosmetiekjeanny.nl/wp-content/uploads/2023/05/2023-05-16-12-13-42.png
It’s difficult to assess what needs to be done without seeing the live site.
I would say just add it as a background image through Appearance > Customize > Backgrounds. Reference: https://docs.generatepress.com/article/backgrounds-overview/
Add it to the body, and set the top section of your site to have a transparent background so that the body background is visible.
Thanks Fernándo, I will make a start witch your suggestion.
You’re welcome, Tis!
