caitrionam96
Hi, I set up a different generatepress theme on my website, and although I love it, I can’t seem to add a sidebar without seeming to skew the single posts page in an unflattering way. So I completely altered the single post hero. While it looks good on the logged in page (https://ibb.co/hyKF0TQ), when I check on incognito mode it’s completely different (https://ibb.co/nCtCXnm). Could it be WP Rocket or some tool that is triggering this? Thanks in advance.
yeah it looks to be WP Rockets caches and / or used CSS option needs clearing.
A way to test this is by adding:?nocache
to the end of the URL in the browser which should load the page without WP Rockets cache. And if I do it on that problem post on your site it loads correctly. -
caitrionam96
This is a very cool hack and it worked right away. I turned off “Optimize CSS Delivery” and it worked
If that setting was helping improve the site performance, then try re-activating the option and purging the WP Rocket caches.
It may resolve the issue.If it does not and you need that setting, check with WP Rocket support; they should be able to help isolate the issue.
