LauraUoB
Hi
I wonder if you could help with some advice: we regularly use buttons or links with icons to create social media links in footers etc.
But we get a failure on Accessibility checks for “Write lists or groups of links semantically
WCAG 2.0 A 1.3.1”What’s the best way to approach this using Generate Blocks Pro?
The buttons/links should be in a ul li, and display as a row.
Laura -
Hi Laura,
Where are you getting this error? Is there more information regarding the failure as well?
LauraUoB
This is from Silktide – an accessibility checker.
The error is:
WCAG 2.0 A 1.3.1
Lists of related items should be written semantically as a list.
Usually, this means rewriting these to use the
<ul>
or<ol>
tags.This allows assistive technologies to more easily navigate from item to item, or past entire groups of links if the user wants to.
We’re getting this if a user tries to add a set of buttons or links with icons for social media links.
I’ve attached a site that has the error.
if you want to use the Headline Block then you would need to use the
role
attribute.1. Add a Container Block and in its block settings Advanced > CUSTOM ATTRIBUTES –> Add Attribute:
add:
role
->list
2. Add your Headlines inside and give those attributes of
role
->listitem
LauraUoB
Thanks, David, that’s really helpful 🙂
You’re welcome
