timodeecom
Hey!
Can you please take a look at this post?
https://testing.timodee.com/video-marketing-building-your-own-teleprompter-for-under-50-bucks/I removed the date and also the author element etc.
Still, there is a space over the video. How can I remove that space?
If I show the featured image though, there is no space.
Thanks,
Timo -
How are you removing the featured image on that post?
Let me know π
timodeecom
I just unchecked it at the “Disable Elements” area for this post
Thanks,
Timo -
Hmm ok.
Will you be removing the featured image for all single posts? If so can you uncheck the Display featured images for Posts in the customizer?
https://docs.generatepress.com/article/adjusting-the-featured-images/That should fix the issue.
Let me know if you want to keep the featured image in single posts sometimes then we would need to use some CSS.
timodeecom
Hey Leo,
I will have posts that contain a video & text and posts that will have the featured image & text.
So, I guess I need some CSS π
Thanks,
Timo -
A layout element option would be better actually:
https://docs.generatepress.com/article/layout-element-overview/So create a Layout Element and check Content Title under the Disable Elements tab:
https://docs.generatepress.com/article/layout-element-overview/#disable-elementThen use the Display rules and manually add the posts with video as the start of the content:
https://docs.generatepress.com/article/layout-element-overview/#display-rulesThen uncheck the option in the metabox in the page editor.
Let me know if this helps π
timodeecom
Hey Leo,
I did what you said, but it has the same effect – see here:
https://go.screenpal.com/watch/cZfvVlVMwsaThanks,
Timo -
Did you do the last step in my previous reply?
timodeecom
Yes, I did:
https://app.screencast.com/JC1OASTAHfcsk -
Your screenshot shows a check mark beside the Featured Image option and it needs to be Unchecked as mentioned π .
timodeecom
I tried to uncheck it before too. Looks like this then:
timodeecom
Nevermind! It works now – I disabled both elements now.
No problem π
timodeecom
Sorry, another problem came up.
I cloned the post to test it in case I have no video for a post.
Unfortunately, the image isn’t showing:
https://testing.timodee.com/video-marketing-building-your-own-teleprompter-image/Any idea why?
The images is there. Only a small line shows.
Add this CSS:
body:is(.single-post) .featured-image img { height: 100%; }
timodeecom
That works just fine – Thanks, Alvind π
